Lexus LS460 SE-L no power going to rear left door.
Hi All
My rear left door
Symptoms :
Door would not lock or unlock using key fob or keyless or using lock / unlock button on drivers arm.
Soft power auto closure not working
sun shade is not going up or down
Memory button green LED is not lit
light behind door handle is not lit
I cant lock or unlock door from outside (keyless )
But window goes up n down and LED light on window button is lit
any help please ? should i disconnet Battery for 10 minutes ?
so today decided to check all fuses but all seem ok.
I have small issue here and not sure about it. if you look at picture below, according to book 5A fuse VSSR POWER CONTROL SYSTEM should be in bottom slot but at the moment its in top slot. I am scared to move it.
Can I just try it ? what would happen ?
also took door apart and wondering if this control module is at fault, I have ordered one from eBay and lets see.
The door ECUs are reliable but I guess could be at fault. You must have power to the ECU because some of the door functions are working - that is powered through the cabin fuses, not the engine bay fuse box.
Me personally would swap the fuse around, cant see anything going wrong putting a fuse into the empty slot, also might of been worth swapping module with other side to see if it was at fault.....
tried fuse no luck :(
I cant be bothered with taking other door apart, ordered new /used module from eBay £35
lets see.
keep ideas coming guys
Connector is not getting any power when I tested it with test meter, but when you connect module power comes in. SO i think module must be connected to draw power.
with module connected i noticed power is coming in but not going out to other bits connected to module as in, light, sun shade motor, actuator, small LED etc.
So i am guessing its defo module unit at fault. I have ordered one from breakers so lets see when it turns up. I will report back. Thanks
1 hour ago, ColinBarber said:
Just be careful. If a shorted motor blew the control board it could do the same to the new one.
Good point. But how can I avoid this happening again.
I am wondering how to test new module carefully? So this doesn’t happen. Any precautions ?
