throttle body/magnetic clutch problem
Scenario
Whenever ambient temperature drops below say 7 degrees celcius, my engine management light starts flashing along with trc light, the light will then tend to go out some days later. This issue only occurs at start up. When this happens, usually a headlight fuses at the same time. The performance is crap also when the temp is low outside until the car warms up.
Where should I start looking to solve this problem? Thanks
