David
CLARA
On ‎5‎/‎14‎/‎2018 at 9:06 PM, CLARA said:
Can anyone advise what each fuse does (engine compartment) , I want to piggy back a supply for front parking sensors Thanks
Thanks for this but I am not confident enough to know what I am doing  All I need to know is which fuse to piggy back onto to get a feed for the parking sensor box.  I have got the sensors working but the car would not recognise the key and I could only start the car by touching the fob to the start switch, also I could not lock the car so had to disconnect the piggy back
Appreciate you help Thanks again
Thanks, Battery is OK when I remove the piggy back fuse the car recognises fob & locks OK If only Lexus showed what each fuse does life would be so much easier!
Thank you for this, I looked up fuses & DIY maintenance but could not find this anywhere. Will look again This is just what I needed. Many thanks
