IS200 SportCross Boot miss aligned
Hi! I'm a new owner of a great running IS200. Great running yes, but quite poor exterior and at the moment my biggest pet peeve is the trunk gap on the right side. I can put the tip of my finger between the rear light and trunk. While the left side Its impossible, any suggestions how I can fix this issue and perhahps what might have caused it? Any help is greatly appreciated!
Hi William, I wonder if  it's been removed at sometime (for whatever reason), and not  replaced properly ?
I imagine there is some adjustment in the hinges ?  I wouldn't think it's the light cluster, as that seems to
line up at the bottom.  Has the car been involved in an accident ?
On 5/15/2018 at 7:55 PM, ColinBarber said:
Sorry, thread hijack.
Glad this popped up again. I couldn't remember where I'd seen it.
Colin, would you happen to know how to adjust the bonnet catch on my 1st gen IS? There's a very slight up and down when the bonnet is closed. I assume it's the two bolts either side of the catch but wondered if you knew otherwise.
Richard @rich1068 have you tried unwinding the rubber bump stops at each front corner?
If the bonnet closes without needing a hefty slam, then the catch is in a good position.
If the bonnet closes without slamming, then the catch is in a good position.
Ah, good point! No I haven't. Thank you. I didn't think of that.
