LIGHT PROBLEMS 2000 GS 430
Couple of nights ago I was flashed a number of times by oncoming drivers.
As there is no level control switch I must have an auto  headlamp level control but there is no warning light in the instrument cluster.
The following day I found that one of the headlamp washers had disappeared - how are they fitted? - can they just drop out?
I am confused - please help
John
They should just push together. There is a metal clip, a bit like the ones on the electrical connection blocks.
Easiest way to see is pull the other one out. It’ll have some resistance from the spring return, but will pull forward.
Sent from my Iphone using Tapatalk Pro
