RX450h LED Headlight sections
Hi All, I have a RX450h 2009 Premier with the LED headlights.
Does anyone know what the section marked in red is actually for?
Can this section be wired to be constantly on so as to be used as a DRL and if so what are the wiring colours that supply the LED in there?
The headlight is supp;ied by a block connector with the following wires, L/Blue, Black, White/Black, Brown, Gray
The side light is supplied separately as is the turn signal.
