Speedo Conversion
Mel
Hi. I am very new to this forum. I have just picked up my new Tezza As Zed. I'd like to know how to change the speedo chipset to convert it to mile. Is it a DIY job ? Where can I buy the chip? How much does it cost. Help..Please.
Welcome Mel and good to hear yet another Tezza owner , The speedo conversion is quite easy if you see the post below it explains the wiring side of it The chips are abot £45-£60 and can be purchased from many places but I buy mine from http://www.f-e-s.demon.co.uk and it comes with all instructions needed. I take it that you will have to s.v.a. your tezza?
Regards
Galee
Yes it would of had to be converted to pass the s.v.a. test unless they took it off after? You can check just unscrew the casing around the speedo 3 screws then unscrew the speedo 3 screws and see what is behind there.
Regards
Galee
