Mines the same. Never had a car before with such bad interference. Radio 1 & 2 is about all I can clearly get. Going to get Lexus to have a look next time it's in.
In older cars used to have a transistor on alternator which stopped interference so wondering if there is something similar on new cars. Funny thing is my taxi radio is fine with dash cam
Perhaps aerial in windscreen is damaged some where. Never used to happen just recently started. It's so annoying have to turn it off.
Pretty sure the aerial on these are within the rear screen - within the wires layout that you see that heat the rear screen when its frosty. Check the wires have not been damaged or the adhesive to them has dried up - especially in the hot weather we have had.
Had a similar problem with radio interference on my 2006 IS250 with ML system.  Sorted it by removing and cleaning up my Battery connections.
Might be worth a try, it was an easy fix for me.
Dec.
