Coils and Plugs
IS200_758
Hey i have a friend here with an is300 and he has after market ngk (blue) coils in his engine as well as double tip iriduim spark plugs. I have and is200 and im not sure if i can do the same simple mods to my car, can someone tell me if there are aftermarket coils (hotter) as well as double tip spark plugs that can work on the is200 engine that will make it perform better.
thanks in advance for the feed back
You can probably do it but it won't make any difference. The stock setup is fine, if you want the ultimate plug performance the use Denso IK20 plugs but it won't really make much difference on the IS200 engine other than placebo.
