Help Required (IS300H)
1 minute ago, DerrickB said:
i have a second hand item which your showing you can have it for free
Cheers mate but i got sorted in the end by another member on here, is it the mode select button or the entire assembly you have?
Thanks for the instructions - I did the same, wired to the floor lighting - way easier then the official Lexus guide.
i went straight to the 2 wires that go into the floor lighting remove the under panel below the glovebox and above the pedals, the panel on the passenger side is held in with a few clips
the panel on the drivers side is held in place with 2 screws
disconnect the plug from the light and you will see the 2 wires
just tap into these.
here is a video of the lights in the dark.
these lights cost me £64 ,
£29 for the lights
£32 for dhl posting (received in 4 days )
£3 import duty
My white panel came today from wish. 30mins install - delighted with the result.Then installed logo puddle lights too.
Sent from my SM-T580 using Tapatalk
1f3a4c09170cf21a9741b56be60c4a23.jpg&key=bc98df6eb0e3e4a2b0a94a5f99f0ebb556fd8a42cb135a30b2d6f647b49fd936
https://drive.google.com/file/d/1lDUq0ISlyJRXcN_qudl0CYf80n7UxAmD/view?usp=drivesdk
