02/2004 RX 300 Audio Fault Martin Levinson system
so all functions and displays well
steering control is in place
AM I MISSING SOMETHING as system turned however if I turn the
volume knob on centre console its not changing from Zero (0)
steering wheel volume controls do not respond either
but mode and chanel change do .
is there a mute or audio fuse or any help welcome
Hi John the amplifier is a weak spot on the Lexus Vehicles - members have reported faults on the LS430 and LS460 before. Sadly I have had this problem - it turned out to be the power supply on the amplifier - I had mine repared by SVT services in Glasgow for £285 inc return postage.
When mine packed up I heard a loud crackle and thats it - all the functions on the screen still worked inc volume counting up but no sound at all.
On the 430 there is afuse for the amp - might be worth looking if this is the case with yours and checking it.
There is a simple diagnostic you can do through the touchscreen for the LS430 - not sure if it will work on your vehicle.
thought to delve deeper as i was removing rear trim anyway
simple task to pull out the lot located AMP in rear boot space
awkward to access unless you break it down patiently
took me an hour fortunately i have the space and tools
although i am NOT a mechanic .
passenger side fuse not blown need to check others
some pics attached
I looked on the ClubLexus usa  site and did the following ..
removed all Amp + Radio fuses front engine and passenger side .
disconected Battery and waited 5 mins .RESULT
Well well i now have the Volume working but no sound so where as before the audio control stayed at zero
i now have the full range volume control up to 58..
But still no sound from any speaker NOT EVEN A Crackle or Hiss
HELP
LOL
Blimey you've been busy and well done to you stripping all that down. If the controls are working then I'd think the amp is at fault. If possible try a different amp just to test. Even a 2 channel amp will test if sound comes out.
