Faulty Rear Light
whitie
Recently I've been getting a fault showing on my rear light, so today on my lunch brake I thought I'd go out and change the bulb/check the connection.
What bright spark came up with the Idea that you have to remove the rear light cluster just to get to the bulbs!!! :blink:
First time a rear bulb went on mine I had to soak the bolts in wd40 for a few hours before I could shift them. I also tried numerous petrol stations and Halfords branches before I found somewhere with the right wedge bulb in stock.
