Club Discount: BG Fuel Saving Products - 10% Discount + Free P&P
BG Fuel Saving Service Products – Performance and/or MPG Improvement Guaranteed!
BG Products have teamed up with the Former Top Gear Stig, Ben Collins to highlight to motorists that clean engines work better
Watch the video here:  https://www.youtube.com/watch?v=hl5JTxRTQhw
Car manufacturers, engine producers and even the fuel companies now acknowledge the problems caused by carbon deposits - the sooty residues left behind after combustion.
So what can be done?
Deposits are a natural by-product of combustion and without preventative maintenance, accumulate over time.
You may have seen adverts from the big fuel companies talking about the additives added to their premium fuels that tackle deposits.
BG GB say the weakness with this approach is that this additive package contained is such a small percentage, you need to constantly use these more expensive fuels to get any benefit at all.
And far better, more cost-effective results can be gained from once-a-year dedicated treatments.
The Guaranteed BG Fuel Saving Service comprises one product to treat the fuel system and a second to revitalise the vehicle’s oil system:
  • BG 44K® Fuel System Cleaner (or equivalent for Diesel) goes in the tank to clean the fuel system. It’s vitally effective at cleaning carbon-covered fuel injectors.
  • BG EPR® Engine Performance Restoration® flush softens and dissolves hard-to-remove deposits from piston rings, restoring peak compression, ensuring maximum power and efficiency.
If we supply a BG Fuel System Cleaner and BG EPR® Compression Restoration Flush and you do not notice any improvement in your vehicle's performance or economy we'll give you a full refund - Guaranteed! (Money-back guarantee subject to vehicle been driven at least 500 miles and claim made within 3 months of purchase)
Former Stig, Ben Collins, tested the BG Fuel Saving Service on his own Land Rover!
Ben tested the BG Fuel Saving Service on his own Land Rover Defender which he felt was running okay. Since using BG, he reports it's so much smoother - like taking the clock back to when it was new!
The Dyno results before and after visually prove the improvement. The curve demonstrates much more consistent torque (available power) throughout the rev range, with an impressive max gain of 7ft/lbs.
Watch the test at  www.bencollinstestsbg.com
A long-established US chemical company, BG Products put significant investment into Research and Development in order to develop effective products that break down and remove carbon deposits.
BG supply their Powerflow Suite of Professional-use Decarbonisation Tools to Service Centres across Great Britain.
These utilise BG's own-designed and manufactured high-quality chemistry and delivery systems to intensively clean carbon from a vehicle’s critical components, safely and effectively.
Find out more and identify your nearest Centre at www.bgpowerflow.com   Find out more here
Member Discount
BG Products GB are offering Premium Members 10% Discount off the RRP and Free P&P on their range of pour-in Performance Improvement Products
Simply call 01284 777934 or email info@bgprod.co.uk to place an order and obtain your discount
Please quote Discount Code when placing an order
https://bgprod.co.uk/
View full discount
