For the past few weeks my brake pedal has sometimes felt hard to push when starting the car (gs300 mk3) always starts and pedal pulls to floor, but after some reading I found out the non return check valve can cause this possibly if its not sealing as it should, and with it been a cheap and easy solution I figured I would try and sort it.
Can anyone point me in the direction of the part numbers required or where on earth to buy them, I have looked around but cannot find anything, maybe they are not specific to a lexus and some toyota parts will fit but I don't know, I expect some of you will have had this problem before as it seems fairly common at one point or another.
Thanks.
