Wipers stuck on auto mode :(!
There are a number of us who have had the same problem. I have just fixed mine by fitting another INT relay I bought off eBay for £2.60 quick and easy exchange and all working again now. If you search the forum for ' wipers stopping' all our discussions are there with a picture of the relay location.
As above change the relays they are located under the brake fluid chamber in  a small fuse box. my car had this fault from the day I bought it from Lexus Swindon I had a year extended warranty with the car and Lexus bristol had the car three times for the fault they tried telling me there is nothing wrong with it in the and there master tech changed the wiper motor but fault returned 6 months after. Now out of warranty I search the American forum and found the same fault on there. If you search the part number of the relays they change to a new number which tells you that must have problems with them. I am a mechanic myself and find it poor how Lexus bristol changed the wrong part and also tried to charged me for it even though I told them it had Lexus extended warranty. Don't Lexus have tsb's and shared dealer faults like other brands I have worked for e.g. Hyundai Citroen fiat even.
Not surprised at your Bristol experience - first time my CT went there for a service they tried to tell me I had a oil leak and when could they book it it.  Told them it was used approved and had an extended warranty to be told oil leaks were not covered.  Checked the warranty and found they were covered, and hey presto its no longer a leak, and best to see what it looks like at the next service........where it had completly dissapeared
  • 1 year later...
Hi Bob...new member here with same wiper issue. Could you please post that eBay link and also a link to that thread with the relay location please?
Hi Brian, just input the following into eBay search and a few come up at different prices most around £3 to £6. A little dearer than when I got mine but still not too dear.
TOYOTA LEXUS DENSO RELAY 5 PIN BROWN
9098704004
The relays are with the abs relays in a 5 inch relay box in the engine bay on the drivers side just below the brake reservoir.
Used a smallish screwdriver to release the catch on the left hand side, relays are on the left. Removed the INT relay as they are plugged in.
Hope this helps
Bob
