I have mentioned elsewhere on the forum of the following issues but thought i would try and diagnose them first myself.
Rear foglights are not coming on, rear reverse camera is not working showing a blank dark grey screen and the boot release button on the boot itself is also not working.
Bought another camera and tried this but still the same problem. Checked the foglight bulbs and they appear to be in perfect working order. I daren't try and order a boot mechanism for fear of wasting more money and time on something that works perfectly on the remote and from within the drivers side compartment.
Has anybody experienced anything similar? Model is 2008 GS450h.
I don't have any experience of this, but it sounds like the common theme is that they are all on the boot lid. It might be worth checking the wiring loom for breaks where it goes from the boot lid to the main body.
No expert on Lexus, but it sounds like a blown fuse and with the power shutting boot if it is out of adjustment it may not stop trying to close and the motor overheated and blew the fuse. It was a common problem in a Transam I owned and sometimes a fuse covers different components.
I will check the fuses again as i have already checked them once in the boot. It sounds like everything is connected to one fault but its trying to find the fault that is frustrating.
How many fuses are related to each of the items?
