Injector question
Hi. I changed the seal on one of the injectors that seems to be a common occurrence on here. However a month or so later it is now smoking as to put it. But it's not to the level that it was before when the seal had perished. What would be causing this? Would it be because the injector isn't set correctly or is it a different issue
