Cross Climate Tyres can’t find
Anyone found across climate tyres for the 2016 rx
I have 235 55 R20 stock summer tyres fitted,
wanted to replace with cross climate to cope with the ever changing season we get each month !
Ideas anyone
Michelin don't seem to do the Cross Climates in 235 55 R20.
You could go with 275 45 R20 with a -1.5% change in outer diameter, which Michelin do offer.
Does your handbook recommend an alternative wheel diameter for winter use?
Personally I'd drop down to R18 (which I see from the handbook is an option for your car) Michelin do a 235 65 R18 which keeps the tyre with reasonable for winter use and probably a lot cheaper!
https://www.oponeo.co.uk/advice-and-tips/tyre-size-calculator/235-55-r20#alternativeTireTool
