Looks good Craig.
Go to do mine now!
What bulbs are you using?
You must post some instructions for me.
Alsoned to replace my headlampthat is badly stone chipped.
Have seen some info in the group archives but can't find it now.
Can anyone point me in the right direction.
Looks good Craig.
Go to do mine now!
keith its simple..1 screw in a bracket you can see holding the indicator unit undo the bulb then push the unit forward from behind as there is a popper type thing the bottom of the unit next to the headlight unit once its out its just a case of breaking out the orange lens.. you have to break the whole bit away first then (i used a pr of pointed aviation snips) shake the unit upside down abnd use your fingers to get an edge you can snip it takes 10 mins or so to get it all out..
craig
