Correct Tyre Pressures
Jock
I recently bought 18" alloys & tyres...
I was washing & hoovering out my Lex today, and decided then to check all the fluids and check the tyre pressures...
I read somewhere else on LOC the correct tyre pressures for the standard wheels & tyres, is it the same for 18" (225/40ZR 18)
Cheers
Jock
Yes tyre pressure is the same for the 18's
Mine came from lexus with 18s and there is a small sticker on the 17" page that states
"For 18 x 7 1/2J wheel with 225/40 ZR18 tire use tire pressures and wheel torque below."
Vehicle load up to four occupants:
Front 33psi
Rear 33psi
Vehicle loaded up to capacity weight:
Front 36psi
Rear 36psi
The recommended tyre pressures increase if you intend on traveling at speed in excess of 100MPH - but being a responsible person you wont want to know them :P
