Windscreen Washer issue
northernstar
Hi
My driver's side windscreen washer nozzle on 2012 F-Sport (RHD) doesn't work anymore. Over a period of a few weeks, the stream became progressively weaker and now it doesn't work at all. Passenger side is fine, rear washer fine also. Doesn't appear to be any blockage in nozzle. Do you think this is an easy DIY fix or would a repair be covered by extended warranty?
Thank you for any advice.
locate the non return valve and swap the 2 outlets around if its the non return valve
at fault the drivers side nozzle will work and the passenger wont if not looks like a
blocked nozzle
here is the valve you are looking for
https://www.amazon.co.uk/Koauto-Washer-Windshield-Toyota-85321-28020/dp/B07F36P2CL
1 inlet from the pump and 2 outlets to windscreen
