Screen wash jets
Not sure how simple this is to fix, but the windscreen washer jet on the passenger side on my ISF has stopped working.  Hoping it was just a blocked hole in the jet I looked at it today but it appears more complex than I thought.  Each washer jet unit is embedded in the bonnet, so really not accessible unless you take take the unit out.  Does anyone know if each washer jet has a built in pump, or is there a pump for both units? Are they simple to replace/fix?
thanks for any help.
Not the same vehicle but my Traffic van always has a blocked jet they did not fit a filter on the reservoir which I think is part of the problem. I regularly have to set to with a needle on the suspect jet then put my finger over the working jet to block it up completely this seems to work every time. I guess you have tried the obvious anyhow.
