Second Service
Dixgas
Had 2nd service on my GS this week, it included " front and rear brakes stripped cleaned and greased " I can't recall this been done on any previous service, is this related to the problem of sticking calipers do you think?.
  • 4 weeks later...
I imagine it would be to prevent sticking calipers. I used to drive a Prius as a taxi, and it was a very common problem. Every Prius that I knew of suffered from it, especially those that were rented. It didn't help having them washed often, the jetwash blasting the brakes a couple of times a week. The problem was solved by stripping, cleaning and greasing them every other oil change, ie twice a year. The Prius specialist I used would do this very quickly whist you waited.
He has pre built bearings and suspension units on the shelf. If you pre booked, a front wheel bearing was done in 25 minutes, the whole hub being replaced. The worn hub was then rebuilt and put on the shelf. He obviously charged his labour for the whole job, not just the 25 minutes! He's brilliant, saving drivers being off the road for long periods.
14 hours ago, ColinBarber said:
I'd agree expect the series IV GS doesn't have a sliding calliper design, it uses a 4 pot design that doesn't suffer from that issue.
I bow to your superior knowledge CB, my low mileage and tendency to use regen. braking maybe the reason for the attention to the brakes.
