So I had a mixed day of success with making (or not) a few lighting mods on the GS.
Boot Light
The easiest and the most successful mod.
The boot light in the Mk4 GS is.... bluntly, abysmal. It's a single wedge bulb, but for some reason it isn't even a 5W but a 3.8W. You could be forgiven for not noticing that there is a boot light.
Very very simple to replace - unclip the light cover, pull the bulb out, replace and refit the cover. The key is the correct choice of bulb - the bulb is held pointing directly downwards, so you want an LED W5W 501 that emits in that direction. I used the (very expensive, but brilliant) Philips X-treme Ultinon:
Philips-Xtreme-Vision-Ultinon-LED-W5W-T10-6000K-2_750_750.thumb.jpg.cb9e8778b1deb9091dc50af6793a5717.jpg
So, without further ado, the result (same exposure value on the camera)
Puddle Lights
Next up, the puddle lights in the bottom of the door mirrors - the ones that light up when you approach the car with the key.
These are 5W 501s, and a bit of a pain to change. I followed a guide from ClubLexus, but really struggled getting the second mirror back together.
This is nothing like as dramatic an improvement, as the housing design is more efficient and it has a 5W bulb. The housing holds the bulb side-on, so the end-emitter LED doesn't work as effectively as it does in the boot. However, I did it more for the more sophisticated colour (the murky brown of a filament lamp seems rather dated these days).
I have some pics I'll process if people are interested, but they're not brilliant.
Indicators
I also wanted to change the front indicator bulbs for chromed bulbs (I prefer the look - sadly the rear cluster can't be de-oranged).
In this, I failed.
The bulbs I bought, Silvatec WY21W, turn out to be identical (even to the part marking on the bulb) to the XTEC ones I have in my Leaf. However, they could not be fitted into the GS (nor could I get one of the XTECs in) - the bulb holder in the GS is very tightly designed and the clip features of the chromed bulbs simply would not fit in (even after I attempted to grind a bit off the bulb using a whetstone).
It's a shame that Philips and Osram don't offer their chromed amber bulbs in a wedge fitting
No.
These bulbs are just courtesy/comfort and the car doesn't monitor them (they are not part of the legally required/tested/etc lighting on the vehicle). There are no errors (which people wrongly describe as "CANbus error").
