any ideas on how to fix my clutch
BJ_Pow
I've recently upgraded my clutch to a stage 3 one but the bite point is now really high and it slips after about 30 min of hard driving. has anyone had this issue before and know of any ways to solve this?
I'd check for correct push rod play, in case it is too tight and applying pressure all the time. When hot also bleed the system, if fluid comes out with force when you first undo the bleed nipple on the slave cylinder then there is clearly pressure in the system when there shouldn't be, which could be the lack of free play and also air in the system.
m_cl_0002.pdf
