RX 300 front wheel bearings
I replaced a front wheel bearing (O/S)around 3 years ago and it's done about 12,000 miles since. Unfortunately, wheel bearing noise has returned, and from the drivers seat it appears to be that one again, but I'm not sure. It also sounds noisy from passenger side, but not quite as much as driver's side. I left it with my usual repairer and he said he can't tell either and didn't want to do the wrong one. It would make sense that I should replace the opposite to what was done previously, but it certainly sounds like the O/S again. This was replaced with quality bearings, but nowadays, everything is of poorer quality so I'm in a quandary. it doesn't help that the wheel can't be spun to listen for bearing roughness as car is 4wd. There is no wear discernible ether side when car jacked up. Any ideas?
Pete
Does the noise lessen if you sway the car in a particular direction? If so it usually indicates the alternate side is bad. Eg swing right, if the noise lessens then the left one is probably bad.
Failing that being conclusive I guess your options are either take a gamble, bite the bullet and do both, or take the car to a garage that has better diagnostic tools like remote microphones in order to accurately diagnose the problem.
I've tried all the usual things, so I'll be taking a punt at the side that was replaced 3 years ago as it sounds noisiest from there. If I'm wrong then so be it. It's starting to get annoying now even though it's my wife's car.
Pete
