4wd 2jz-gte Powered Is200!
scollinguk
Hi all, first post and all but hopefully have an interesting one.
USDM and JDM have a AS200 station wagon with 4wd using the 2JZ-GE engine but only with an auto box. Would it be possible to take the running gear off this and put onto a saloon IS200? if yes could you then put in the supra's 2JZ-GTE engine using the supra's gearbox and run the engine 4wd? Like i said above i think this is possible as the transmission would go to the distribution box of the 4wd system rather then going straight to the front axle.
Also could someone tell me the normal kerb weights of a supra and an IS200?
Cheers Guys
Scott
considering the effort required to get the 2jz-gte engine into mine, to then swap over the 4 wheel drive aswell, and incorporate this into the supras 6 speed would be quite an undertaking.
the US does not get the 4x4 sportcross only japan (gita)
