I haven't heard the bubbling for a while however fans still don't spin.. gonna change the rad..
601f2d4f074b258ab69f8a0bd897fafa.jpg&key=7374c55ebcae31e541881fd9edebcd2e3250db34ec46bd2a4ffb0ec91b3eba23
What's the extra 2 hoses at the bottom? Did I buy the wrong part?
Sent from my CLT-L09 using Tapatalk
The two extra hoses for the auto transmission fluid cooler.
Sent from my Iphone using Tapatalk Pro
Attempting to clear the block as the fans don't come on themselves
Drained the coolant from the radiator drain thing... Front of car was already up... refilled the coolant... Temp and power on full blast and NOTHING
Top hose gets hot, bottom hose stays cold, no bubbles in the radiator fill cap
Whats my options peopleeeeee 😢 I'm stuck... I've gone through all radiator threads and can't find a solution.
Changed thermostat, waterpump, temperature switch sensor and radiator..... KMT
In the wise words of Lucie from Love Island. "I just don't know what to do 😥".
advice????
Can we recap on what is happening, or not happening?
The temp gauge goes to half way, and no higher?
Have you let the car run for long enough for thermostat to open (to get flow through the radiator).
If it gets too hot (temp gauge) and the rad bottom hose is still cold, did you put the thermostat in the right way up (with the airlock toggle at the top), and right way round (if it’s the wrong way round, it won’t open)?
If it’s not overheating, and ambient temperature is not letting it get too hot, the fans won’t come on, so maybe there is nothing wrong.
Do you get heat in the cabin?
Sent from my iPhone using Tapatalk Pro
Temperature gauge goes halfway and no higher.
I've left it running for a while, engine gets really hot, top hose gets hot, bottom stays cool
I can't confirm on the thermostat, I took out the old one and replaced with the new one in the same orientation but it may have not been working before either
The outer fans work but the middle ones do not.
Lol, so got my OBD2 £5 eBay connector thing so I could see how the coolant temp was behaving
Coolant how up to 90 before game kick in.. normal? I'm so excited, I think I was over cautious of the engine literally getting so hot you could feel the heat when you step out the car.
And ERM, The reason for the middle fans not working was because I had the directional setting set to clear the window.
My girl moved it to point at your face after she asked "have you tried this"
She's never gonna live this down
On another note, 70 miles from £30 fuel.. is that normal? Also, 0 -60 in 13.5 seconds... Faaaaaking hell it's a tad slow. Very comfy tho
