Rear Fog Lights
gib
Couldn't open it either. Got this message:
Sorry, an error occurred. If you are unsure on how to use a feature, or don't know why you got this error message, try looking through the help files for more information.
The error returned was:
Sorry, but you do not have permission to use this feature. If you are not logged in, you may do so using the form below if available.
Not the first time I got this error.
Then just click on my username next to my post to bring up my profile. I've probably got some better pics of the lights on and off somewhere. I'll have a look sometime...
How much red you get show through depends on the bulb. Minimum is with clear LED bulbs but then the light you get is a faint pink. The bulbs you get with the lights are dark magenta when not lit so don't show through too much but when lit are not really bright enough and are pink. Best red colour when lit is to get a clear bulb and paint it with transparent glass paint (cranberry colour) but they show through more red when unlit. Can't remember which bulbs were in when the photo was taken.
How much red you get show through depends on the bulb. Minimum is with clear led bulbs but then the light you get is a faint pink. The bulbs you get with the lights are dark magenta when not lit so don't show through too much but when lit are not really bright enough and are pink. Best red colour when lit is to get a clear bulb and paint it with transparent glass paint (cranberry colour) but they show through more red when unlit. Can't remember which bulbs were in when the photo was taken.
Gives the same error when I click on your nickname :duh:
