glawrie
GS450h - Active Stabilizer Suspension System
Hopefully this is a very simple question to answer...
I have a 2007 GS450h SE.  How do I tell if it has APSSS fitted?
Thx!
Two 12v batteries in the boot.
Wasn't it only available on SEL's?
Helpful - thanks.  Defo only got one 12V Battery...
Trying to work out what suspension dampers are needed: parts lists have two for each wheel depending on whether APSSS is fitted.
In passing - for motorcycles it is common practice to rebuild shock absorbers, but this seems not to happen for car ones.  Is it possible to refurbish / rebuild the shocks on the GS?
My GS is similar age/spec to yours and only has 1 damper per corner.
A forum member has managed to rebuild his GS dampers but it is not common place for OEM units.
Do any of your dampers leak?
I'd forgotten just how big the ASSS install is;
221385d1315096703-anyone-with-run-flats-
Occupying the spare wheel well.
Thanks for the info.  Just had MOT fail with three dampers needing replacing (both front, one rear): seems the best I can do for new replacements is to order from US (about £700 for the three), and none apparently in breakers right now.  So trying to work out if there is another way of sorting.  I'm not greatly experienced at cars, but on motorbikes there are quite a few specialist shops that strip / repair dampers, so wondering if similar exist for cars.
Gavin / @glawrie, and MOT fails sucks.  This is independent feedback outside of Lexus right?
After I bought mine, Lexus tried to convince me that all of my dampers needed replacing, even tho they were bone dry. Yet they passed an indi's inspection and have been through 2 MOT's since.  A good money spinner for Lexus that.
I recall that Lexus Lincoln quoted me around £700 all in for them to change all 4 dampers, so it maybe worth ringing around a few stealers for quotes?
I've had good experiences with RockAuto for parts from the USA but dampers seem to be constantly out of stock.
I vaguely recall someone on the forum using NipponAutoSpares.com for dampers.
Good luck and let us know how you get on.
Thanks Farqui - yes report on dampers is from an independent MOT shop, so don't doubt.  My experience with Lexus dealers has been poor.  Prior to hitting the mileage limit for warranty cover I used our local dealer for servicing, but they were not so honest in reporting how to fix issues (and in requesting to do repairs for non-existing issues) so for a few years now I've had independents work on the car.  I am asking around for quotes - but first one I got back (from a Lexus dealer) was £1600 to change all four dampers... which seems absurdly expensive.
NipponAutoSpares don't appear to have the dampers for sale any more, but found excellent parts identification database complete with diagrams at japan-parts.eu and pretty good prices from LexusPartsNow (at least compared to UK based sources).  But would prefer simply to repair the ones I have got... but perhaps that is not possible.
How long have your dampers been leaking?
I see this thread from a few years ago, did you ever get the dampers replaced?
It is the same car - like you I got someone else to look at damper that was said to be leaking and they said it was OK - so didn't fix at time.  Got four more years from them 🙂 but this time I can't dodge the task.  7zap looks like it uses same data as japan-parts, but nice interface 👍
On 3/6/2019 at 5:15 PM, Farqui said:
Good call checking part numbers, I tend to use; https://lexus.7zap.com/en/eu/lexus+gs/334510/gws191r-bexqhw/2/
Just a quick note guys, I know I'm late to the party but for parts always fill in our enquiry form and send it to see what we can offer you,
You never know we may be able to order what you need and we beat main stealers
https://www.lexuspartsdirect.co.uk/contact-us-genuine-lexus-parts/
We have a discount code in the member's area aswell
