2 hours ago, Daveyboy20 said:
Thank-you! Any special tricks to fitting or relatively standard?
Easy peesy. From memory, so may not be totally gospel... open boot, there are a couple of blanking plates either side of the lens that you prise off to reveal two screws, undo these and the lens can be eased off being careful with the lugs that will pop out as you pull the lens away. The bulb housing twists a half turn or so (if I remember correctly) to undo and pull it out from the lens. Pull out the bulb, and push in the new one and re-assemble.
