Propshaft coupling
johnnyroper
The propshaft coupling/donut on my 220d is cracking and I suspect it’s causing the slight driveline vibration at speed.
can anyone recommend a stockist or is it dealer only part?
tried looking online but all I can get up is used ones from fleabay.
  • 4 years later...
I have just had the MOT at my local Toyota garage, on the advisory was a cracked prop shaft flexible coupling disc.
Has anyone else had this issue, I'm assuming its not a common problem.
