My apologies in advance, I have seen this thread somewhere but cannot find it ...
Driving home tonight in my beloved RX300, the amber engine management light came on and the VSC light.
Stopping and starting made no difference.
Once home I did undo the petrol cap - - no whoosh. I'm not sure if that's significant or not.
Happy to take it to the garage but are there any obvious checks an incompetent DIY'er can do?
Regards,
Piers.
Unfortunately the first step with warning lamps is normally to check the logged fault codes and go from there so without an OBD reader it's a bit of a guess for the average DIY'er.
Still well worth your time casting your eye around the engine bay wiring and components in case something is visually suspect.  Hope fully it's something obvious (and cheap!)
In some cases I think the VSC is tripped if the engine throws a fault so it should just be one initial fault rather than two separate issues.
Update... I hope.
Borrowed a reader from a colleague. The 1 code mentioned a Knock sensor. P0330 I think ...
Car was still driving but in limp mode I think. ( Never happened to me before...! )
Having 'researched' on the internet, I tried a 'reset' by disconnecting the Battery for a few minutes.
Reconnected the Battery ( found the Battery strap that secures it very loose. ).
No amber warning lights. Driving normally.
On its first re-start I need to hold the throttle pedal down as it idled, but having now driven about 30 miles, it's all back to normal.
Fingers crossed it is.
Why? I DID go through a large flooded puddle too fast. Water ingress?
Don't know. So fingers crossed. Limpness gone.
Hope it's not because of the puddle because that means a likely exposed wire. I think the knock sensors are pretty hard to access on your engine so not easy to check connectors.
I'd still do a bit more with the fuel filler cap. A clean around the filler neck can help too. Do check the rubber seal ring inside the cap as well. You never know.. Just be extra careful not to drop any dirt down the filler pipe.
Hope it stays away. Gave me a scare when the dash lights lit up on my first real motorway run after buying the RX.
Yes, I 'did' the filler cap this morning, as an extra...
23 hours ago, PCM said:
Update... I hope.
Having 'researched' on the internet, I tried a 'reset' by disconnecting the battery for a few minutes.
Reconnected the battery ( found the battery strap that secures it very loose. ).
Limpness back :(
( Off to Japex soon )
Had a C1201 also.
All reset at the garage.
50 miles and all clear but if it comes back it'll go into the garage next month ...
All of a sudden going through that puddle becomes more relevant. You can upset a speed sensor with even a high speed car wash spray. This sensor will also cause a limp mode (which the fuel cap/o2 sensor et al faults won't).
I hope the garage did look at the sensor for any broken insulation etc. Also a quick visual of the wheel hub.
Do you have the full list of codes they got from the car?
The garage took a quick look when I took my wife to collect her car.
They checked the code(s).
There were 2 in total, the P0330 and the C1201.
They cleared them and the plan is hat it goes back in if the issue occurs again.
We shall see.
If it does go back in I'll mention your points.
Japex are very good.
Car back to me tomorrow.
New knock sensors and wiring loom.
