Main Oxygen (Lamda) sensor or not???
Glider
Hi everybody,
checked fault codes on my LS after some electrical repairs, it came up with 3, so cleared them, and took the car for a 20 mile drive, then checked again, I have 1 fault code 21 main lamda sensor left bank (or oxygen) i then checked out what issues I might get because of this, and or symptoms, which were engine check light on rough running on idle and funny smells.....well I have none of these, has anyone else experienced  the same please,
Many thanks
Phil
PS I will change the sensor just in case
Mine went in exactly that way. Engine management light on and car was running fine. An independent charged about £95 for the OEM lamda sensor (Lexus wanted £202!). About an hour and half labour to fit and test run. All Ok after. See VSC below.
  • 4 months later...
