RCA on standard car is it possible
Lillew206
Hi all
I'm new to the world of Lexus is200 and been told the RCA and quick steer kits from Lexi break are a worth while upgrade but my question is
Can I fit RCA kit to a standard height car or would it put stress on ball joints and mess up the handling
  • 5 weeks later...
No, the whole point of the RCA is to lower the car a bit without affecting the LCA and tie rod angle. You'll be fine. Go for it.
It's probably the best way to drop the front an inch in terms of suspension geometry. It might increase your toe-in/negative camber every so slightly so you should maybe get an alingment afterwards.
The quick steer i don't really know anything about tho.
