What is this
seqo
Hi, I saw a video where someone was replacing their pcv valve in their is350, I was wondering if this hose you can see coming out of the plastic under the engine cover is meant to be on an is250. Mine doesn't have a hose its just blocked off.
Can we see pic's of your car in the area highlighted.
Just under the highlighted area, on the back of the cam cover should be a valve with a hose that should snake off around/into the back of the inlet collector doohickey.
Here's a good thread with plenty of pic's for the info requested https://www.my.is/forums/f139/is250-carbon-build-up-fix-451746/#post6777450
Images 5, 6 and 7 are the pcv valve, follow that hose to the back of the air box.
I also have a blanked plug like yours and a pcv feed to the air box.
