Headlight adjust switch test
Hello guys.
Just want to no that if I remove my headlight levels switch on my dash and test with multi meter will I get a resistance reading nd if so what should I get.
Both headlight levels don't work but got power from the connection plug.
My dash switch has power and reads 0.2v with ignition on but the switch seems dead hence my question.
Many thanks guys
On 4/13/2019 at 5:59 PM, brunskill43 said:
Hello guys.
Many thanks guys
Does anybody no if there is a hidden relay switch for the headlight adjust levels as replaced my levels both sides and my adjust switch on the dash and still not working and all fuses work.
