Ketzy
Battery hooked backwards!!!!!
Hi guys and sorry for bad English! Accidentally I hooked the batery backwoods on my lexus is220d 2008. I checked the fuses and 2 of 30A are damage on engine department. The car starts but has the Abs light on, P/S light on, airbag on, the power steering is not working, navi, electric windows, mirrors, rear back lights, day lights and I can lock or unlock the car. What you guys think it happens, I burn the Ecu, if ecu is damage I still turn on the car? I was very stupid, I know
It is very likely you still have other fuses to replace. There are hidden strip fuses along the side of the fuse/relay box that is difficult to both see or replace.
John.
So the Ecu should be OK? you have any picture with hidden fuses?
Sorry I do not have an 220d to take pictures of, but virtually all Toyota/Lexus cars have a clear plastic cover usually at the side of the fuse box. Under this cover "that cannot be removed from the top" is a long metal strip with a series of connections. It is this metal strip that is the fuse. Blown sections can be seen through the plastic cover, but the complete strip has to be replaced from the underside of the fuse box.
John.
U say about this fuses, all this looks like they r ok
@Ketzy This might help:
It may be worth getting a cheap multimeter to test all the fuses for continuity.
