Brand New NX Takumi - is this normal
Hi was hoping someone can check something out for me. Picked up a brand new NX and loving it so far. However noticed these 2 bumps on the rear door when I went to put the child lock on and weren't sure if this is normal or manufacturing defect. Hoping someone can check their car and let me know if this is on their car too. Don't really want to go back to the dealer if this is normal
Many thanks in advance.
Sent from my SM-N960F using Tapatalk
If in doubt, then take it back to the Dealer immediately. Where are you based?
Thanks for your time. Based in London and the dealer is 30 minutes away.
Want to avoid going back to the dealer because
1. It's difficult to find time (took close to a month to find time to pick up the car if you can believe it) due to work and family commitment and
2. Didn't want to head back if it's normal hence the initial check.
If it is as I think is not normal obviously will need to go back to the dealer asap
I just checked mine and it seems to have it too, it was hard to capture a photo of it.
But it is small and circular with the center slightly pointy
Just been to check my 2018 NX.  Same bumps next to the child lock switch.  Never noticed them before but they are definitely there on both rear doors so I assume it’s normal.  Both are uniform, identical smooth bumps.
