Is200
engine running 100% one day cut out after turning corner, and wouldn’t start.
Engine starts now and is running but idling high, idling up and down between 4000rpm and 2000rpm when started and is over fueling.
No codes are showing up or lights
anyone had this problem ? Or solution ?
The hunting may well be because of wrong signals from a part of the throttle system. I'd check around the throttle body/associated sensors for loose/broken connections. Probably check the earth points too.
