Door speaker problem
I don't believe in coincidences so I reckon it's something you've done while you've been working. Go back over what you've been doing because you may have just nudged a connector or perhaps pulled a wire too far etc., etc.
Thanks for reply. Turns out that if you remove the sat. Nav. Unit from the boot, you will lose sound from the drivers door speaker as the sat. Nav. voice runs through it. Splicing 2 of the wires will sort it.
