Mark beard
Mark beard
Wheel out of balance, possibly a buckled rim, possibly tyre bulge/damaged from potholes.
Get the wheel balancing checked and inspect the tyres.
Shake through steering is usually front wheel/tyre issues could be exacerbated by suspension wear.
Gotta start with the basics...
All wheel nuts secure are they? ( No I'm not taking the Michael, see below )
Any work done on running gear recently inc tyres?
Tyre pressure all good and close inspection ( inc inner Walls) of all rubbers OK ( cuts,bulges or irregularities )
After checking all this ( no cost) then next course would be getting wheel alignment done. ( last done ??)
Steering Wheel shake problem here https://www.lexusownersclub.co.uk/forum/topic/118865-ls400-steering-wheel-shaking-between-60-65mph/?tab=comments#comment-1083521
paul m.
Basics, Basics Basics. https://www.lexusownersclub.co.uk/forum/topic/118801-ls430-knocking-sound-after-brake-job-help/?tab=comments#comment-1082960
