SEAN ls 430 ireland
LS 430 SUSPENSION DOWN AT BACK COPRESSOR PUMP SCREAMING AT ME
HI DOES ANYONE KNOW SOMEONE WHO KMOWS THERE WAY AROUND THE SUSPENSION IN AN 2002 LS 430 PLEASE IM DOWN AT THE BACK AND THE PUMP IS GETTING NOISY 00353899868085 SEAN THANKS FOR THE HELP
there's a great deal of info on this Forum when you search for it !
I don't have a Ls430
Hi Sean
You either have a leak in the air system or the ride height sensor is faulty.
You could try to diagnose a leak by listening for escaping air whilst the air compressor is running.
Failing that it will need to go to a garage - preferably one with air suspension experience
Hope you get it sorted soon
Also check that the arm from a height sensor isn't broken because they do break.  This is from a different vehicle but the long arm or rod at the end is similar.  Is it down on one side or both?
Another way is to brush soapy liquid on joints or even the whole length of the pipes themselves - where it bubbles, there it leaks :thumbsup:
  • Club Hybrid Poll
  • 471 Hybrid Reliability
    1. 1. If you were to consider buying a Hybrid model over 5 years old, would you be worried about the reliability of the Hybrid system?
      • Not really as Hybrid systems are always reliable
      • Not if it had a Manufacturers Warranty on the Hybrid system
      • I would not buy a Hybrid model over 5 years old
