Dash light and Seals
varunsharma
Dear All,
Please see photos below.
I have 2 questions:
1) this light came up on the dash. I have taken the car to the local tyre merchant which checked tyres and rims ... all is fine.
No pressure loss/no cracked rims.
Is there a reset for this light please?
Or am possibly missing something?
2) I have had terrible leaking issues ...
HOWEVER, I sorted one issue (water ingress through a side vent)
BUT now there seems to be an issue with a seal around the hood ...
any advice please on sourcing new rubber?
The "pad" in the photo soaks up the rain ...
THANK YOU in advance ...
Varun :)
If the pressure is definitely correct all round and you're certain they are the usual pressure you have them, (you could be certain by adding more air but not overboard) then it could be the Battery in one of the sensors. The battery can be replaced, although some are soldered in. It's a pain trying to find the correct one though.
6 hours ago, Geoffers said:
If the pressure is definitely correct all round and you're certain they are the usual pressure you have them, (you could be certain by adding more air but not overboard) then it could be the battery in one of the sensors. The battery can be replaced, although some are soldered in. It's a pain trying to find the correct one though.
Thank you Geoffers - I think a trip to my local mechanic is in order!
