the L.hand mirror ,when I use it to see how much room I have for parking, it doesn't come back the way it should unless I press the button a few times is it  possible to take it out and find out what is wrong and how do I do that.??
There is an option to set it to tilt down when you select reverse so you can see the kerb.
See the owners manual for details on setting that.
If it is failing to move the mirror when you press the buttons, the switch(es) need a clean.
https://www.clublexus.com/forums/ls-3rd-gen-2001-2006/451425-mirrors-no-longer-adjust.html
