Auto tilt mirrors
My mirrors don't auto tilt in reverse and I can't find a menu to enable it. Should they or does the is300h have this function?
am I missing something? Just figured out how to get a signal on the dab radio it's not the easiest car to figure when I'm not up on techy things.
Make sure that the mirror switch is evenly set between L and R.
Every YouTube video I seen said it had to be selected l or r and the function was disabled in the centre. I can't get it to work in any position and not even sure if the function is fitted
It's the opposite in my handbook! Doing as you suggest disables tilt on reverse.
Handbook says to select either left or right to enable the auto tilt function.
@Shada, have you actually set a position for the tilt on reverse?
Yes Ive tried putting car into reverse adjusting mirrors and then back to park. They just won't move on their own. Am I missing part of a sequence? I know it doesent have the power fold when locking function so thought many they don't reverse tilt either?
