Rx 450 front bumper underrun 09-15
Hello everyone🍻
This is my first post.Ok..Straight to the point.I have attached two pictures  (as you can see below) of rx models, preface lift and facelift.my question is :
Will facelift underrun (silver part in picture)would fit pre facelift .As to me they are looking same🤷🏻‍♂️
I own 2009 rx 450h luxury model
Many thanks in advance😑
I see this topic did not made any interest to any of you😂
perhaps this might: i have i stalled today rear bumper lip which i have bought on eBay lexusparts.
pictures before and after.what you think?🙄
Yes, it looks good Darius, I like it.
I think it's most likely that you didn't get any replies to your first question because no one knows the answer 🙂
Herbie you are probably right. Maybe Darius is the first to fit a cover(s) to pre 2011 model.
It looks much better Darius. Let us know if you manage to do the front as well. If you provide info on cost and how difficult is to install the covers, maybe other pre 2011 owners can do the same.
Rear cover wasn't straight fit.although it fitted exactly on the bumper as it should, underneath the bumper (black cover) i had to mark and drill out four 8mm holes in order to fit provided rubber plugs and washers with screws.then inserted those rubber plugs and drove those screws in.took me 15 min to fit rear one.i have paid on eBay 278£🙈
With the front one is a bit tricky there is two types for the generation three  2012-2015 with different part numbers :
2009-2012   PZ402K095000
2012-2015   PZ402K095200
Although they look very much the same, but  the part numbers  one digit is different.this is why i am a bit hesitating drag it in to the online basket and purchase🧐
i think i will have to order both and send one back  to the supplier;)
49 minutes ago, Morkunas said:
Rear cover wasn't straight fit.although it fitted exactly on the bumper as it should, underneath the bumper (black cover) i had to mark and drill out four 8mm holes in order to fit provided rubber plugs and washers with screws.then inserted those rubber plugs and drove those screws in.took me 15 min to fit rear one.i have paid on ebay 278£🙈
Surely you should just order the first one which is for your model year ?
:jawdrop:  Wow, I like the look of it but not at that price! Am I right in thinking that it doesn't actually perform any function and is just purely a decorative bit of plastic? Probably cost all of about a fiver to make.
That’s the thing:
2009-2012 is 485£
and 2012-2015 is  275£
I have contacted eBay seller where he has listed 2012-2015 lip for 275£, and asked him if they have 2009-2012 year lip.they have replied- yes, we have and it will cost 485£.it’s a bit odd what 2009-2012 cost more then facelift.🧐
12 minutes ago, Morkunas said:
That’s the thing:
2009-2012 is 485£
I have contacted ebay seller where he has listed 2012-2015 lip for 275£, and asked him if they have 2009-2012 year lip.they have replied- yes, we have and it will cost 485£.it’s a bit odd what 2009-2012 cost more then facelift.🧐
Ah OK, yes it does seem odd.
