Removing audio system 1999 is200
Should be a couple of bolts deep in the area where you removed the heated seats/ TRC panel.
There's another 2 bolts at the top of the stereo unit. To get at them, you need to remove the top part of the dash with the central air vents.
On a car without navigation you literally just grab the top of the dash and pull it off, but it might be different on a car that has the nav screen there.
Sent from my SM-G935F using Tapatalk
