Windscreen washers not working
My windscreen washers are not working, so far i have cleaned the jets with a pin, disconnected the t-joint under the bonnet and checked for dirt, checked no pipes are kinked so next step i guess  is checking the fuse, i dont have a manual but i think its a 30amp fuse looking at the fuse plastic cover index, cant seem to pull it out and check as they are so small and awkward to get to, and i have a habit of breaking things in my hands, anyway question is.....is it a 30amp fuse, could it be the washer jet motor thats gone? anyone else had a same problem?
