Oxygen Sensor
Hi have fault code POO51 coming up. 2010 RX450h.
Oxygen sensor Bank 2 Sensor 1. I believe this is the sensor closest to the front of the car. Does anyone know the part no?
Having a few issues searching for it. Thanks
Hi Barrie, here's a range of O2 sensors and their part numbers; https://www.rockauto.com/en/catalog/lexus,2010,rx450h,3.5l+v6+electric/gas,1444314,exhaust+&+emission,oxygen+(o2)+sensor,5132
A quick Google indicates back 2 sensor 1 is on the front of the engine underneath the coolant tank;
https://www.clublexus.com/forums/rx-3rd-gen-2010-2015/841783-p0051-oxygen-sensor-bank-2-sensor-1-a.html
Will you be investigation and resolving this yourself?
Good luck.
Many thanks. Yes it'll be DIY. I haven't even had the chance to give it the once over and check its not loose/damp or anything. Had 5 minutes in work spare so plugged the OBD in and that came up. Reset and disappeared but came back on when I nipped out at lunch.
